SIEMENS Uninstall... I need some help please.
J.A.du Toit
Sep 2006
N/A
Hi Guys,
Do any of you know how to completely remove/uninstall Siemens software, I would like to start from scratch (Had some problems with the previous installation).
Or is there maybe a clean-up application from Siemens?
Thanks for your help, so long...
Regards
Augusto
Oh, maybe I must mention it's the following applications:
1) Simatic Manager Step 7
2) Simatic Net
3) WinCC
Better to reinstall your PC completely, starting from Windows. Siemens software affects Windows too strongly. Simple reinstallation of Siemens software haven't many chances for success.
I think it isn't necessary to reinstall the
complete 'Windows' installtion.
Look at this link form 'Siemens' support:
link
regards
Rolf
Is It S7 Micro-Win?
I had a bad install of a past version of Micro-Win (s7-200 series) that wouldn't let me remove or reinstall. If this is your problem there is a fix.
I got the following response from support.
I am sending a couple of files they may get you around this , you didn't say what OS , XP, win200 but there is a DCOM setup that will cause it to fail see attached for instructions, also to get out of your situation will need to go into Regedit and delete a folder that contains a piece of the microwin that got installed. See instructions. Do the DCOM check first , also after you complete the regedit routine make sure there is not a listing of this version in the install/uninstall under control panel . After doing all this reboot and try to reinstall.
Another remote possibility is the CD drive , I had to copy the CD to my hard drive and then it installed ok.
Please call if you need additional assistance
I've attached the files referred to.
Edit: Noticed you weren't using Micro-Win, sorry. I'll leave this for anyone that had this problem though.
Nice one DD!
It's a pity this wasn't posted a month ago when my install of Microwin V4.0.3 went pear shaped, the installation didn't like my laptop going into 'stand by' because my battery was low. Out of desperation I reinstalled the lot!
Paul
Is there any way to uninstall all the Siemens S7, WinCC, etc in 1 swoop? I am looking to make space for a Virtual Machine with just Siemens or...
4,065
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
180
86
154
