Hello all!
I am working on trying to use a Siemens WinAC instead of a S7-317 PN/DP when testing applications against a Beijer (Mitsubishi Electric) E-1101 panel. WinAC is configured with WinLC in slot 2 in the Station Configuration and an IE General (PCMCIA network card) in slot 3. The configuration is also done in STEP 7 to correspond to the Station Configuration.
Now I want to connect the panel with the PC but panel is going crazy. It show comm errors and tries to access non-existing blocks etc. The panel is using a Siemens driver called "S7 ISO over TCP/IP" that works perfectly with the S7-317.
Does anyone have experience in using WinAC and maybe even the E-1101 panel?
