Hey,
I have Siemens OP177 panel and I am having a problem mapping the function key leds in WinCC flexible 2005 SP1 HF7. I cannot find a good example of how to do this. Is it so that I can just toggle a bit in the PLC and make the LED flash? I made an word array tag in the PLC data block. When I go to the WinCC template screen, I can put the LED Tag tagname there and then it ask for a bit number. I have put in zero for bit number. I tried to use the WinCC simulator and toggle bit zero but I do not see the LED flashing on the simulator nor do I really know if that is possible using simulation. Does someone have a good example of mapping the LED's? Also I noticed an excellent "feature" there that when I go to the template screen, click on the function key, then select view - properties, the LED tag field is grayed out and will not let me enter in a tagname. Also sometimes the "use global assignment" field is grayed out where I cannot select it. Is there another way to get those available again? I did a rebuild and then all the function keys allowed me to select "use global assignment" but the LED Tag field is still grayed out. Any clues on this?
Best Regards,
PK
Best Regards,
PK
