Siemens wont connect to ANY PG/PC setting
DanC2188
May 2013
England
I have had issue after issue with Siemens Simatic Manager, it worked great and now all of a sudden it died. I have removed and reinstalled in every single possible way from every single forum posting to get it work and now it still wont.
I now get the following error "ONLINE: connection could not be established..." or "Online: ERROR"
I have uninstalled and reinstalled this software completely 8 times now and even taken off TIA and WinCC versions too so the laptop was a Siemens Free-Zone.
Can anyone help before i am forced to have my IT dept wipe my laptop fully and reinstall everything again from scratch??
Thanks in advance!
Just to add to this - I can ping the IP address wirelessly that i want to connect to so i know this is not a network problem. My Simatic manger stopped, randomly, connecting to systems last week and then all of the PG/PC interface settings disappeared and now I have them back after 8 re-installs but i cannot get connected to anything that is still reachable.
Yes sir, I did the data folder rename from the previous recommendation. I also do have the latest versions of Simatic Manager. I think the next step is to wipe my windows PC and reinstall.
I have an Siemens S5 135 system. The CPU 6ES5 928-3UB12 Will not go into run mode even after a MASTER RESET or AN OVERALL RESET using a...
2,867
Hi I have a Siemens S5 922 CPU with eprom that will not go into run. the stop LED is blinking slowly. I have tried to perform an overall reset...
4,840
225
153
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
311
