Siemens
I'd recommend getting a hold of a local Siemens rep to discuss things. Sometimes there are wrinkles to complicate things a little.
That said, all you need is Step 7 Basic (for the 1200). It includes WinCC Basic, for the HMI, which can also be purchased separately.
Your PLC should have Ethernet onboard, so connecting should be relatively simple. The Basic panels come in both ethernet/Profinet and serial/Profibus variants, hopefully you have a PN one.
If you don't have any of the parts yet, and this is your first time with Siemens, you may be able to get a starter kit, which is a bundle of all of them together.
Any version of TIA will work. The basic panels are included in the standard package.
I would recommend going for the newest version, and at least V14. The previous versions have been very buggy at times.
207
147
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
308
116
Hi everyone hope you'll well. Is it possible for me to download a Crack version of tia portal v13..sorry to say this but the software is very...
199
