siemens
manmeetvirdi
Oct 2004
India.
750
hi there
Just a simple question
Is there any Special Bit or SFC or SFB in siimatic manager which
generates pulse after every one second or one minute?
Please let me know about it, as I'am sure there must be.
regards
Manmeet
You could use a timer/time of day interrupt..... How long does the pulse have to be ? Any tolerance specification ? What is the application ?
In the HW-configuration you can define a clock-byte. One of the bits can be used for the 1-second timer.
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
124
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
165
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
173
115
333
