Siemens
rmonroe
Guest
R
In our plant we have the Siemens S5 115 PLC’s and S5 95. I have had experience with the Siemens S7 300, but I do not recall if the S7 programming software work’s for Step-5 family. I’m laying out our maintenance budget and would like to purchase the software package.
Any recommendations?
rmonroe
Confusion, confusion, confusion.
In Siemens-talk, S- refers to hardware; STEP- refers to software. Then it's match the numbers.
You use STEP5 to program S5. You use STEP7 to program S7. No, you can not use STEP5 to program S7 or STEP7 to program S5.
Regards
Ken.
Siemens STEP7 is for S7 only.
Siemens STEP5 is very expensive (approx. 3000 EURO). And it is very cumbersome to use as the core of the program originates all the way back to CP/M (operating system from before DOS).
Search for "S5 for windows". Its easier to understand than STEP5 and also much cheaper (approx. 500 EURO I think).
164
84
152
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
185
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
182
