JDCROCKETT724
I am doing exactly what you are asking about right now. I am using a comfort panel HMI programmed with WinCC in TIA and I am using step 7 5.5 for programming my S7-315. Unfortunately you cannot simply connect the TIA to your classic Step 7 to get the tags, but Siemens has made a program to make what you are doing as easy as possible. You can download the software here: https://support.automation.siemens....lib.csinfo&lang=en&objid=56078300&caller=view The instructions on how to use it are pretty helpful. The only thing I don't like is when you import all the tags you want to use they come in with a 1 second "Acquistition Cycle" I change them all to 100ms. There is probably a way to set that as the default, but I haven't figured that out yet. If you need more details then let me know.
