Simatic HMI TP900 Comfort
lyntonius113
Oct 2009
ZAR
Hi Gents, i need some direction if possible,
i am trying to make my tp900 switch to different screens, i have made new screens and numbered them,
how do i now make this TP go to a new screen, i send an int to the HMI... then nothing,
Where can i find the link between the Tags in the HMI and the actual Screen number? :eek:
Chat soon
I'm not quite sure what you are trying to do.
The normal way to do change screens is to use a button. If you drag one screen from the project tree onto another screen's editor window, then it will automatically create a button with that takes you to that screen when you click on it. You can also do this manually b by going to the events tab for a button's properties, and using the appropriate system function (I think it is activatescreen or changescreen, something like that.
Hi MK42, Thanks for the quick response, what i would like to do is make the PLC force the HMI to go to a screen when there is an error on a specific fixture, lets say fixture 1 gets an error i want the HMI to jump to that screen,
internally i can jump around from place to place with buttons, but any idea how i can do it from outside?
Mike, thanks allot i went and scratched around there... after some time i found it,
the tab was hidden so i just dragged it up and presto!
(the tab was squashed down and looked like part of the screen border)
Thanks for the pointers Gents
Does anybody have 6AV6881-0AP40-0AA0 or 6AV6881-0AQ40-0AA0 - SIMATIC HMI MEMORY SD-CARD, 32GB? I need image copy (flash card back-up) of it, or at...
1,037
I connected a Lorex security camera to a Simatic KTP700F HMI via a PoE switch. It shows up on the screen, but the refresh rate is atrocious--like...
4,191
Hello everyone, I have met the following issue in a project: there is an I/O field where you can set parameter "number of decimal places" for an...
1,191
Runtime configuration of simatic hmi wincc explorer made screens & automation system Hi Friends, How do I configure and execute RUNTIME of...
3,269
Hello everyone, I need help with alarms on simatic TP1200 comfort panel. Since I am at the beginner level, I can't figure out how to save alarms...
4,772
