Simatic Net 2006 cp5611
Stephen D
Oct 2012
Wales
Hi
I need some help!! Siemens Simatic Net 2006 cp5611 has been discontinued, I have a PC with a dodgy hard drive so looking to do a new install of xp but need a copy of the install for the Simatic Net. I can transfer the licence key over to the new hard drive. The problem is with a third party software (National Instruments NIDAQ runtime application) which cant be upgraded to Win7. Any ideas where I can get hold of a copy please.
Thanks Steve
You are looking for Profibus Softnet-S7 2008 (6GK1704-5CW71-3AA0).
this can no longer be purchased the normal way, but maybe if you contact Siemens Support it may be possible at a markup price.
If you still have the original software package with a floppy disk license, then you can get the license recovered. But you have to purchase a socalled "Service Card Premium" (9LF1110-6DA11-1AA1 for 1 support case) for Siemens Support to accept to help you recover the license for "legacy" software.
Thanks Jesper
I have a copy of 2008, its the disk I need for 2006, have tried Siemens but they just say its discontinued.
Cheers
Steve
Yes they say it is discontinued, but you can recover the license and install it on a new PC (with XP).
As I wrote you need to purchase one Premium Support (not expensive) and then contact Siemens Support.
You can also just install the software without a license.
You will then get nag-screens every now and then.
IMO that is perfectly legal, as long as you have the license certificate to prove you have purchased the software.
I don't know if this is the right place for the subject at least I'll try. The company has one of the oldest computers that is a master Windows...
742
I had a system running WinCC v7.0 SP3 and SIMATIC Net V8.1 SP2. The WinCC Runtime project was reading symbolic tags (e.g. D435.HMIVars.Start) from...
1,688
My problem is that I can not approach variables from OPC Scout 10. I can see Data blocks but not variables. I'm using TIA portal v14, SImatic...
2,884
Hello All, I have a system of 2 PLCs Siemens CPU 315 - 2PN/DP (with a program Simatic S7 V5.5) and PC station runs Siemens OPC server Simatic net...
20
7,341
Hi Friends, I'm trying to set up/configure a Simatic Net on an already existing project that uses TCP/IP Connection. I formatted the PC-Based...
27
5,142
