Simatic OPC Server 2008 SP2 OPC Scout
MHennel
Jun 2002
Cincinnati, OH
66
I am trying to set up OPC communications to several Siemens CPU-317-2PN/DP via a ProfiNet connection. I have created all of the .sti files with no problem. I am attempting to get the basic communications set up using OPC Scout The problem that I am having is that OPC scout seems to be able to communicate to only one of the PLC's. In diagnostics it shows the connection to the other PLC's as broken. The PLC's are connected to the OPC server across various switches, but I believe that at least two of the PLC's are through the same switch. Looking for some clues as to what the issue might be. Does anyone know what Port number OPC servers uses to connect to the PLC? If I knew this I could make sure thatis not being blocked. Any other suggestions would be greatly appreciated.
Mike
My problem is that I can not approach variables from OPC Scout 10. I can see Data blocks but not variables. I'm using TIA portal v14, SImatic...
2,896
Hello All, I have a system of 2 PLCs Siemens CPU 315 - 2PN/DP (with a program Simatic S7 V5.5) and PC station runs Siemens OPC server Simatic net...
20
7,384
I have a client that has a PC (win7) that runs the Simatic Net OPC server. To this OPC server there are several S7-300 CPUs connected from...
3,116
I have an OPC server running that has unspecified connections to several different S7-300 systems. I'm trying to understand how Siemens is...
7,421
My company has been working with Siemens equipment mainly. I've Step 7 v5.5 installed, and TIA V13 portal installed and WinCC 7.0.3 installed...
1,678
