Simatic S7-200 Siemens one output not working
hinddhindsa
Mar 2013
www.plckart.com
193
HI.Friends in my Simatic S7-200 CN CPU224CN Relay output Siemens PLC which is installed in a TOWER CRANE,output1 is not working,but all other outputs and inputs are working well.
What can be the possible hardware faults.PLC is in RUN state,i am not able to take back up because it is password protected.Is their anyway to Hack that Password.? Please help.
If you're sure the output is activated insided program code and contact didn't work, hardware is bad
CN modele is probably the reason...
Use another output or replace this Chineese copy CPU by a real Siemens One
As far as I'm aware there is no way of 'hacking' the password. I know that you can clear the PLC (in other words set it back to factory settings) without the password but if you don't have a backup of the code then that isn't going to help you.
Can you not get in touch with the original programmer (or their company) some how to get the password. Ask around and find out when the last modification was done to the program and who did it. Then try and chase them down to get the password.
Also, try a few obvious ones like the company name etc.
Good Evening , It has been several years since I used Siemens Software . I’m looking to purchase the software for a Siemens Simatic S7...
503
Hi all, First time posting here. I have a Siemens Simatic S7-1200 controller that I intend to use for a small project at home. I also have a...
2,033
Hey All, We recently acquired a new used machine off the surplus market. there are two sections to the machine, each with its own PLC/HMI and...
46
11,854
Hello - I have an old PLC file for a Siemens Simatic S7-1200 and I just need to see the ladder logic. If anyone has Siemens software, can you...
4,553
Hi, all. We have one AB drive (powerflex 525) and one SIEMENS plc (simatic S7-1200). Is it possible to make a connection between them via...
10,661
