Simatic S7 OPC UA configuration issues
randrews
Apr 2014
Mississauga
Hello,
We recently acquired a Siemens line and we have a station running the S7 opcdaserver. I want to test out the OPC->ODBC service from Matrikon, however I've discovered that the UA service is bound to the internal IP address of the PLC lan. I need to reconfigure the UA service to listen on both connected network interfaces of the PC so I can connect the OPC->ODBC service running on another system on the network.
I know nothing of PLC and OPC protocol. However as the IT administrator, I've been charged with the task of investigating getting the data from the PLC's into a database for integration with our ERP.
Any help is appreciated.
Have you contacted Matrikon's tech support regarding your dilema? They should be able to resolve your problem.
Unfortunately I cannot speak to how Matrikon's server works in that we are a Kepware distributor.
My problem is that I can not approach variables from OPC Scout 10. I can see Data blocks but not variables. I'm using TIA portal v14, SImatic...
2,895
Hello All, I have a system of 2 PLCs Siemens CPU 315 - 2PN/DP (with a program Simatic S7 V5.5) and PC station runs Siemens OPC server Simatic net...
20
7,382
I have a client that has a PC (win7) that runs the Simatic Net OPC server. To this OPC server there are several S7-300 CPUs connected from...
3,113
Hello! Please help with the answer to the question of the right choice of TI and TD parameters for PID FB41 block. I have a process model in...
27
11,457
I have an OPC server running that has unspecified connections to several different S7-300 systems. I'm trying to understand how Siemens is...
7,420
