Simatic Wincc Flexible 2004 -->2005
STL???
Sep 2005
UK
879
Our company purchased WinCC Flexible 2005 Advanced, But delivered was version 2004. Upon querying this with our supplier a second disk set was supplied - WinCC Flexible 2005 ~ Upgrade for WinCC Flexible 2004 Advanced.
Firstly i installed the 2004 version + licence key without problem, When the 2005 installer ran, i got a popup box requesting removal of previous versions of WinCC Flex - Great 1 hour wasted!
OK here's my question, has anybody also upgraded from 2004 to 2005? The installation performed correctly and i installed 3 licences
1. WinCC Flexible 2004 Advanced
2. WinCC Flexible/ChangeControl 2005 Advanced Upgrade
3. WinCC Flexible 2005 advanced Upgrade 2004 to 2005
But the program still moans about the licence and will only run if you use the temporary 14 Day licence offered @ startup.
I have installed/uninstalled the software now 3 times without success!!!!!:mad:
If you have also upgraded, does your licences differ from mine?
Thanks STL
So under the Automation License Manager does it (with the license key drop down selected) does it have WinCC Flex 2004 or 2005??
It has the 3 licences mentioned in my other post, i would assume that you would need the 2004 licence as the 2005 keys are upgrade, i've also tried various combinations of the three without success!
One more note- are you sure you installed the correct one (advanced, standard, compact) for the authorization you have??
Yes,on each installation i have installed the advanced version and the licences are for the advanced version of each software
hi there
uninstall WinCC2004 and then go for 2005.
all your prevoius projects remains undisturbed.
I had a smooth transistion from 2004 to 2005.
Hi STL.
You should not "install" the upgrade license, only the original license for Win CC Flexible 2004.
The license for Win CC Flexible 2004 must then be be upgraded to the 2005 version in this manner:
In the Automation License Manager, highlight the 2004 license and select from the menu bar "License" .. "Upgrade". You will be prompted for where the upgrade license is located.
The result will be that the 2004 license and the upgrade license disapears, and a 2005 license will be left back.
Note: Not sure, but it is possible that the upgrade license must be on the key floppy disk. IF that is the case then dont panic but simply move the upgrade license back to the floppy. Then do the upgrade manouver again.
Success!! (y)
Thank you Jesper - Finally i can make a start on my first project!
Regards STL 🍻
I see that you are an expert. I have a question if i want to move the license from hard to key disk is there any special partioning for the key disk? Or i can be able to transfer dirctly to a normaly formated disk.
Hi kovi838406.
The only floppy diskette where you can move the license to, is the yellow (sometimes red) license diskette from Siemens.
You can move the license to a USB stick if the license is of the type "floating". WinCC Flex uses the floating license.
Can anyone tell me what the difference is between these two SIMATIC WinCC programming software packages are?: :- SIMATIC WinCC Flexible 2008...
2,429
hi guys i have china Siemens hmi smart 1000 ie , i have software for this simatic wincc flexible china 2008 incl. SP4 , i tried to install this...
4,237
I used to have a SmartServer/Miniweb on remote PC. In HTML pages, I used variables from WinnCC "Tags" directory, and I had no problems. Example...
1,855
I have a machine running on Simatic touch panel Hmi...The Panel failed few days ago..It will take between 5-6 days before the new one arrives.I...
2,381
Hi. We purchased SIMATIC WinCC flexible 2008 Advanced SP3 and I am not able to install it. Details: - Desktop w/Intel Core2 Duo E8400 3.00 GHz...
19,459
