Simens Modbus slave CP341
Siby
Jul 2006
Dubai
27
Hello
im using 3 Siemens PLC 315 2 DP these three PLCs are communicating on profibus master slave.
Now i wanted to communicate master PLC with CP341 as modbus slave but im unable to do the modbus part.
Can any body send me an example or some useful tips for communicating my 315 2 DP with CP341 .
regards
Hello Siby;
Start with the following info, from Siemens' support website:
Modbus Master, Modbus Slave - New Versions and New Catalog No.'s
Concerns products with the Catalog No.'s:
6ES7 870-1AA01-0YA0 Modbus Master for CP341
6ES7 870-1AB01-0YA0 Modbus Slave for CP341
The Modbus Master and Modbus Slave loadable drivers are now available in
version 3.0 with new catalog no.'s. An upgrade is not available.
Version V3.0 permits modem operation in conjunction with a permanent
telephone line.
The new function requires version V5.0 of the configuration software,
which is included in the scope of supply of the CP341 and CP441 modules.
CP341 as Modbus Master manual:
http://support.automation.siemens.com/WW/skm/pdfviewer.asp?HitsPerSite=10&ehbid=html_76%2Fehb%2F1220184%2Ehtm&query=CP340+Loadable+drivers&lang=en&nodeid=1219437&page=1&view=new
CP341 as Modbus slave manual:
http://support.automation.siemens.com/WW/skm/pdfviewer.asp?HitsPerSite=10&ehbid=html_76%2Fehb%2F1218007%2Ehtm&query=CP341+Modbus+slave&lang=en&nodeid=1219196&page=1&view=new
You will need 3 CP341 (one in each PLC rack), one Modbus Master and 2 Modbus slave licences (they are not cheap), and use the parametrization software and communication FBs included in the CP341 Modbus packages.
In the manuals you will find example applicatios for your Modbus comms.
By the way, if you have already setup communications between the CPUs through Profibus-DP, you will find it much more expensive and program intensive to do the same through Modbus. Is there any reason you would want to?
Hope this helps,
Daniel Chartier
There is a much cheaper way - someone here recommended it to me. A Profibus slave with Modbus master and slave built in and USS as well. I will see if I can find what I bought - it works well. Less than half the price.
So I am working on a machine where the PC has died. The PC was running Windows XP, Protool RT, Step7 V5.3, SimoComU and other software. The...
2,477
Hi folks, I'm working on a glass jar packing machine and trying to figure out how this STL code works. Most of the code is in ladder or FBD. But...
25
9,258
Hello All, I have a system of 2 PLCs Siemens CPU 315 - 2PN/DP (with a program Simatic S7 V5.5) and PC station runs Siemens OPC server Simatic net...
20
7,378
hi.. how to sent the data using maestro gsm modem 100 to PLC. i try use hyperterminal to the hand phone and it work..when i use PLC it not...
1,196
High I am fairly new on siemens S7 and have a breakdown with a machine that is referencing a tag called DB50.DBB256 how can I search the whole...
1,670
