Simens PLC DB size
panthripu
Mar 2004
228
Hi guys
Once again i am looking for your help.I am using a DB for communication with WinCC.Now this DB is full and i want to add something more on HMI , How can i tackle this problem.
My second quesiton is related to one of my old thread but bit difference.
I have WinCC v6.0 SP3 running with windows XP. In another place i use winCC v6.0 SP2 with windows2000.Can i install winCC v6.0 SP2 on Windows XP ?
Thanks in advance as usual.:geek:
DB size
Hi Pethoek
Can you please elobrate some more detail.Is this editor with step7 or its additional software ?
Hi Pethoek
Open the project in S7, in the Block's view just double click the DB you want to edit. The DB opens in the editor and you can append to it.
Note. If you do any changes to the initial values of the tags already in the DB you also need to reinitialize the DB.
View -> Dataview (Ctrl+4)
Edit -> Initialize Datablock.
/pethoek.
Hi , I am new user and want to know about small size plc of simens.would please help me.
4,743
We have Siemens S7-300 PLC and HMI computer. They are communicate each other with opc server. We have another computer for data collection which...
1,835
So I am working on a machine where the PC has died. The PC was running Windows XP, Protool RT, Step7 V5.3, SimoComU and other software. The...
2,485
Hi folks, I'm working on a glass jar packing machine and trying to figure out how this STL code works. Most of the code is in ladder or FBD. But...
25
9,275
Hello All, I have a system of 2 PLCs Siemens CPU 315 - 2PN/DP (with a program Simatic S7 V5.5) and PC station runs Siemens OPC server Simatic net...
20
7,395
