Simocode EDS file
This unit supports only Modbus RTU.
If You want Ethernet IP You need 3UF7013-1AB00-0 or 3UF7013-1AU00-0.
The system in question uses a 3UF7012-1AU00-0 (supporting Modbus RTU). My question is in search of the specific eds file for this model. Will help for PLC communication to/from the device.
Maybe I'm missing something. What do you need an EDS file for with Modbus communications?
Good afternoon all. I would like to be able to simulate sending and receiving specific bits between my Simocode pro V EIP module and the...
1,376
:banghead::banghead: Dear all, we have a SIMOCODE that is used to turn on/off some important pumps in the factory. Communication is via...
2,274
Dears Once again need your support. I am starting on a simocode.After factory reset, I am trying to make some changes or reconfiguring the...
3,170
Hi guys, We have a conveyor at work that had a flight break off and did damage to the conveyor. We use Drag Conveyors......I was asked if a...
1,649
Hi I am looking for some help with Simocode Pro V. I have an issue where there was a power fail on site and now two Simocodes are not...
4,375
