Simoreg 6RA70 Drive Field voltage to increase
mvannantn
Jan 2003
bangalore
32
I wants to increase the drive field voltage from 215 to 330.Please any one help in this regards.The connected motor field voltage is 330 with 3.2/5.1 Amps. But the drive giving the out put voltage of 220 and the current is 4.7.
Regards,
Mani
Set the drive up for field current regulation, and set that.
Field current is more accurate, and meaningful, then voltage control, as the winding resistance changes with heat.
Hi All, I have the analog output (0-10vdc) of a Siemens 6RA70 DC drive connected to the analog input on an ABB ACS550 ac drive for speed...
5,568
Hi, i got a 6RA70 with a S7-315 dp/pn. The profibus is working I can see the status word in the PLC And the controlword is received to CB in the...
1,543
hi all any one can explain why brandnew off simoreg dc master 6ra70 2000amp used for dc motor (arm 400v 800amp)(field 220v 30amp) fail in...
2,765
I am working on 6RA70 to replace the outdated 6RA24. When I tried to use the free blocks option S00 I came to know that its not working and...
3,998
Dear all, I have some confusions on communication with CPU314C – 2DP to SIMOREG 6RA70 over Profibus. As we know that according to PPO4...
6,248
