simoreg 6RA70 - Profibus kom. problems
ason
Oct 2005
Home
317
Hi, i got a 6RA70 with a S7-315 dp/pn.
The profibus is working I can see the status word in the PLC
And the controlword is received to CB in the drive,
I have connect K3100 to on/off1 K3001 Off2 etc.
i think that they calls K300x that is the bits from the profibus.
I can see the status word of the profibus that it works when i for a exemple set on/off1
And if i try to use K3100 for main contactor and it switch on/off when i set on/off1 from the plc.
But when i look at the controlword nothing changes,
is there any interlock that i can have missed that stop the signal to get through to the controlword?
Was reading the manual again now, and saw that parameter U712 is to setup witch typ of telegram to use,
that was what i have been looking for long time to day,
Hope that will do the thing đź“š
Dear all, I have some confusions on communication with CPU314C – 2DP to SIMOREG 6RA70 over Profibus. As we know that according to PPO4...
6,246
I wants to increase the drive field voltage from 215 to 330.Please any one help in this regards.The connected motor field voltage is 330 with...
2,461
hi all any one can explain why brandnew off simoreg dc master 6ra70 2000amp used for dc motor (arm 400v 800amp)(field 220v 30amp) fail in...
2,765
I am working on 6RA70 to replace the outdated 6RA24. When I tried to use the free blocks option S00 I came to know that its not working and...
3,990
Hi All, I have the analog output (0-10vdc) of a Siemens 6RA70 DC drive connected to the analog input on an ABB ACS550 ac drive for speed...
5,564
