Simple plc wanted
Jake996688
Mar 2003
Looking to get a plc that has 8 to 16 inputs and outputs with software that will allow me to play a wav file and/or trigger an output. All suggestions most welcome. Jake
Omron have a voice module. Don't know about playing a wave file though. :confused:
more detail on post
PLucas said:
You want a PLC that will play a .wav file??????? :confused:
Paul
Hi, Looking to build simple home automation/supervision system.
Examples A low temp signal to an input will either play a wav file or trip an output or both. Hope this better explains what i am looking to do. Jake
WAV?
AutomationDirect.com does have a WIN-PLC module for the 205 series, but I don't think it can co-exist with a standard PLC CPU. When all is said and done you might be beter off with an annunciator or autodialier like Raco, that will play a specific recorded message when a specific input is tripped.
I have a PC running Entivity Studio set up to play WAV files that tell the equipment operator that their product is out of spec and various other warnings. Studio is a bit expensive to use for home automation though. ;)
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,049
Hi, I have setup the Simple PLC communication in RJ71C24 (Channel 2) for communication between Mitsubishi IQ-R series PLC (Mosbus RTU Master) and...
2,537
Hello everyone, I am a newbie in automation stuff and i wanted to do a simple thing with just a sensor, a blade and a plc. My aim is this - The...
3,991
Hi, I am currently working on a little project and I am wanting to control a fans speed with some PLC digital outputs / anolog output but unsure...
3,457
I have two AB MicroLogix 1500s that I want to be able to communicate with each other via two Transnet 900 radios (one master, one remote). Using...
1,602
