SLC 5/03 battery change
ascot01
Jul 2007
Magnolia, TX
81
I have a SLC 5/03 and need to change the battery.
Currently I have no backup .RSS or .RS1
How do I find out if the program was burned to EEPROM or only in volatile RAM?
I will upload the program as a backup before attempting the battery install.
Thanks for any help !
The best way to tell if theres an EEPROM is to go online with the cpu and try and do an EEPROM save (Comms>EEPROM>Store To EEPROM). If that option is greyed out, I guess you don't have an EEPROM. To check physically, the module is on the CPU board to the right of the battery and is grey with a part # something like 1747-M11.
Even without an EEPROM you can change the battery without making a backup of the program first. The program is retained in RAM memory by means of a supercapacitor. I can't say how much time you have to change the battery, I should look it up, but I don't have the info at hand.
Nevertheless, making a backup of the program is always a good idea. You never know when that supercap is bound to fail. I for one have met Murphy more than enough to do things the safe way.
Kind regards,
Your plan to back up the program before powering down is absolutely the best practice.
But with SLC-5/03-4-5 controllers the capacitor onboard will hold the RAM memory for many days, so there is a 99% chance that your program will still be present and unmodified when you power back up.
Always remember to power down the SLC chassis before pulling any module. So many users are accustomed to ControlLogix RIUP they forget that the SLCs don't do it.
Thanks alot guys for the response. I'll get the uploaded backup safely stored then I'll see if the "store to EEPROM" option is greyed out or not like you said.
That's great the capacitor can keep a prog in mem for that length of time..makes me alot less nervous now.
Thanks again
The capacitor works great until the one time you really, really NEED it to....
I've had too many of those 'moments' to take any risks.
Like the time an old DCS died halfway thru a revision upgrade and the cutsomer replies 'we were supposed to have backups??'
:eek:
Preparation prevents disaster when the unthinkable/impossible/unfixable happens.
I'm ashamed to admit this but I've never had to replace a battery in a SLC. Some how been able to skip that task in all my years. So yesterday...
260
I replaced the battery on old SLC 5/04. It should have had a 30 minute charge in the capacitor when i changed it. Now when i started it back...
1,421
I was at a customer's today and 2 of 3 SLC 5/03s had the Battery Light on. I showed it to the maintenance guy and asked him when the last time the...
3,387
Hi group, just wondering if anyone has knowledge of how long the CPU module battery can be expected to last before throwing the LED. The machine...
2,435
Where is the battery located ? Is it on the left side of the cpu hidden by the power supply? Thanks
1,691
