slc 5/04 and burn eeprom
roy357
Dec 2008
El paso TX
hi all
I have a slc 5/04 with a eeprom fitted on it, when I performance a power up of the machine I need to modify some parameters on the Panel View but when i turn off the machine and power up again those parameters have been changed and i have to introduce the params again I thing the problem is that the eprom is loading its program at the power up of the machine so I need to know how to store the modifications in the eeprom i order to eliminate the necesity of modify the parameters each time a power loss ocurrs. I dont know How to "Burn" the eeptom I will appreciate your help:oops:.
thank you
Roy
Using an SLC 5/04 is there a way to burn the EEPROM without being online with a laptop? I would like to accomplish this, hopefully, from a...
3,425
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
95
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
104
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
111
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
102
