SLC 5/04 and Inview Display Help
chemdawg
Nov 2012
Milwaukee
31
Hello everyone. I have an inview 2706-P44C marquee, with 2706-PDHP DH+ interface, connected to a 5/04 processor through the data highway. I am trying to learn how the messaging system works on this display. So the above items are what I'm using for my bench testing.
I looked at an original program that was written for a line at my work. In the Program files section of the program, it has a LAD 12 - Inview CFG and a LAD 13 - Inview MSG
The in view config is setup with tags:
Message Trigger Address N7:38
Message Data Address N7:11
Message Array Size 16
Variable Trigger Address N10:38
Variable Data Address N10:11
Variable Data Size 16
So with all this info, could someone either show me a sample program that would display messages to the in view?
Lets just say I have a machine with a jam sensor. When that sensor is blocked and the line shuts down, I want the display to say (Theoretically) JAM SENSOR ACTIVE
If I can figure out how to attach the program files I have I will do that.
Any help would be appreciated. Thanks.
Pat
Hi there, Im a bit new at this stuff but ill try my best. Ok atm i have an SLC 5/05 OS501 1747 L551B/C IP address 10.0.2.6. On channel 0 i...
2,769
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
95
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
104
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
111
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
103
