SLC 5/04 communication problems
Caheragh
Feb 2013
illinois
Hi everyone, I have a machine using a SLC 5/04 processor and has a dial up modem ( no longer used ) attached to the serial port. I do not have a copy of the program to see how it is configured. I have not had any luck with serial port communication.
I am using a belkin usb to serial adapter and a null modem cable.
Device manager is seeing the adapter and I have no problem getting on line with any 5/03 processors. I have tried all the baud rates. When I use Auto configure I get a message check cable and parity settings.
Any ideas?
Thank you
The CPU Serial port is configured to communicate with the old modem thus not accepting DF-1 traffic.
You will need to use the processor's DH+ communications port in order to access the CPU application file.
Do you have a 1784-PCMK (laptop) communications adapter? They've been discontinued but you might be able to secure one on eBay.
The 1784-PKTX desktop adapter has also been discontinued, but I am sure there are plenty old ones out there.
Otherwise, the only available PC DH+ interface is the ungodly expensive 1784-U2DHP (USB-to-DH+) adapter- $2780 list!!!...:D
Thankyou for the quick reply.
I was afraid this was going to be the route.
If I buy a PCMK card what cable do I need? will this plug into the 3pin DH+ port?
Hey everyone, I am trying to communicate with a Slc 5/04 plc using the 1747-cp3 cable, RS232-DF1 driver and a laptop. I tried using a serial to...
3,089
Hi Guys, Was wondering if someone would be able to shed some insight into a problem I have. Hardware wise I am running a SLC 5/05 processor...
7,271
Hi guys..and girls if so.I'm a newbi,and also not very clued up when it comes to electronics.Can you possibily assist.My problems are:When I...
3,706
I have an SLC500 1747-L541 running OS401 and I'm having a problem with serial communication once I have completed loading a ladder to it. RS...
65,042
Hi, I have a problem with a cpu slc 5/05 (1747-L552), 32k Mem 0S501 series C, I am using the MSG instruction to ethernet communication, it works...
9,289
