SLC 5/04 Comunication with RSLINX DRIVER ?
If you are connecting to the 5/04 via CH. 0 (serial port), and it has been configured for DF1 (RS-232 null-modem), use the DF1 driver and a 1747-CP3 or a standard null-modem cable. If CH.0 has been configured for DH-485, use the 1747-PIC/AIC+ driver and the same cable(s) listed above. If you are connecting via CH. 1 (DH+), you need a 1784-PCMK card (laptop) or 1784-PKTX card (desktop). You would then use the 1784-KT, KTX, PKTX, PCMK driver in RSLinx.
Need to setup communication with SLC 5/04 using RSLinx and 1761-CBL RS 232 Cable Thanks
6,595
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
96
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
104
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
115
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
105
