SLC 5/04 Programming Cable 8 pins - DB9
WallyPrestone
Aug 2005
Torrance, CA
121
Need help to get the cable to connect to Programming TERM
8 pins to DB-9 female for DH-485 ( NI PCMCIA-485 ) card with laptop interface.
The 8 pins connector ( long connector ) due to RS-232 connector in-Place.
Thank you
As bernie said
I’d still look into the '5' it’s a little more versatile, it has a 9 pin with a adapter, with the '6' you have to use the round pin
you can also check e-bay
This?
Mickey said:
Mickey, I think this CP7 is for the PLC-5, the one that Wally has shown in the pic is the one that I was talking about the 1784-PCM 5/B it has the adapter shown in the pic...I like it better you can tap into at any point with the DH+ and make very long cables if needed, with the PCM6 you are limited to using the round pin and that length of cable...but thats just me
Hello guys. Got Slc5/04 with 9pin d shell port in it. Have cheked some manuals and this port is an RS 232. I want to ask if I could use a generic...
2,357
i have a slc 5/02, but i'm not sure wich software to use (i have both rslogix 500 and 5000) but the main problem is that i dont have the cable, i...
5,705
Does anyone know the correct AB cable I need to connect a laptop serial port to an SLC 5/04 processor programming port, specifically the DIN...
13,327
I am just finishing up my project, which was my first experience with PLCs. I thank everyone that has helped me work through the RIO and analog...
2,971
Hello, I've taken on yet another basket case old machine running an 7 slot SLC 5/03 PLC.... I have run into a situation where I see the same 4...
5,622
