SLC 5/04 to SLC 5/05
pilkingtonk
May 2014
niles
Currently I have on cabinet with a SLC 504 and one with a 505, and I want to swap them. The one using the 504 will be having more Ethernet communications and the one with the 505 will only have 2.
What issues would I encounter with doing this? I am hoping it is as easy as swapping the processor and reloading the program. I heard the MSG instructions might need to be redone, but is that it?
How is Ethernet messaging occurring with the SLC 5/04?
is there a NET-ENI module connected to the DF1 port, or is there a Ethernet to DH+ gateway on your network?
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
97
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
106
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
116
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
107
Hello, I have a ControlLogix redundant controller being set up. The program reads a value from a remote site which hosts a SLC PLC. Rockwell...
89
