Slc 5/04 upgrade to compact logix l30er questions
higginsl
Apr 2015
michigan
Hello,
I have been given the task of upgrading a SLC 500 5/04 cell to a CompactLogix system. I chose to use the L30ER processor. I am keeping the SLC 500 Chassis and using a 1747 AENT card to connect the Compactlogix to the SLC 500 rack. In the original rack there is a Devicenet card. During the conversion , the Device net card will be removed from the SLC 500 rack and the appropiate Device Net card will be installed into the CompactLogix "rack". I have done the conversion from RS Logix 500 to Studio 5000 V 21. I am unable to get the original dnt file. I am trying to set up the communication path in the logic. I understand that that the original Device net card uses 16 bit integers and the New Device Net card uses 32 bit.
In RS Logix 500 , it looks like each of the devices on the network uses 4 - 16 bit words.
I was wondering if someone has done this before and if anyone would be able to show me some example logic to do this?
The Device Net network is for 4 robots.
Any help would be greatly appreciated.
Still learning.
Yes, No, Kinda :) send me a PM with your email and I will send you the program we wrote... its using a 5/04 and removing the CPU and replacing with a RIO then controlling the 5/04 rack with a L72, I think I maybe able to get a project doing the same thing with a AENTR but not sure if I can find it
Still learning.
We all are...
Because you know the device type and data size, you should be able to work backwards to figure out the mapping of the DeviceNet module by figuring out which 4 words in the I: and O: data tables of the SLC are used by each robot.
It's straightforward to migrate from 16-bit to 32-bit data tables on the DeviceNet modules; you just use the COP instruction with an INT[x] datatype destination tag.
The Length argument in the COP instruction is the number of destination elements.
Code:
COP
Source:        DNetScanner:1:I.Data[0]
Destination:   Robot_1_Input[0]
Length:        4
That will copy the two DINTs in DNetScanner:1:I.Data[0] and .Data[1] into the four INTs in Robot_1_Input[0,1,2,3].
Looking into maybe upgrading a SLC 5/05. 13 Slot rack. 12/13 populated. DeviceNet to a panelview. That's going in the bin, replaced by...
40
2,549
I recently came aboard a new company. They (or we I should say) have a critical robotic process line that has an infeed conveyor section running...
1,714
I have a customer running the above. Its about a 10-15 year old installation. They would like to upgrade the SLC 5/05. I would probably use...
2,537
HI guys, wondering if anyone has used a 1746-C9 rack extender cable to connect 2 (or more) SLC 5/05 racks when upgrading the SLC to compact logix...
3,274
I have a customer that has several L36ERM's running SLC's racks (A13's) via AENTR, yesterday I was working on their SLC as they had a NR8 fail...
2,256
