SLC 5/05 eem instruction problems
Shannonh
Oct 2017
Melbourne
Hi all,
I have an slc 5/05 and am trying to read data from an 193-etn using the eem instruction as described in the instruction, but I cannot get it to work.
I keep getting a message error 15h too much data. I have the IP address set up and can ping the slc and the 193-etn.
The slc firmware is version 13 and I’m using rslogix 500 version 9.00.
Any help would be greatly appreciated.
Hi all, I have a pretty simple application that I can't seem to get straight in my head. I have a 525 which is set to start/stop based on...
38
9,422
Hi all im trying to write an EEM Explicit Message instruction in an SLC 505 to communicate with a AB powerflex 525. This instruction requires...
1,726
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
95
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
103
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
104
