SLC 5/05 & GE FANUC CPU 364 Over Ethernet
Davev2005
Jul 2005
San Luis Potosi
23
I want to create a network to work with a GE 364 CPU and Allen Bradley 5/05.
Somebody knows how can I do it?
Can I send msg instructions to GE 364 CPU?
Regards!
If you want data exchange it very simple.
Get CSMSTRLE from Red Lion.
In 5 min they will "talk"
Download Crimson2.0 from Red Line web site,install it chose CSMSTRLE and on Ethernet driver see if you recognize the GE protocol.SLC505 work for sure I test it.
Need more help feel free to ask.
In general, it is very uncommon for logic controllers from competing brands to support direct Ethernet communications between them. If they do, it is very likely to involve a common protocol like Modbus/TCP.
In your case, none of the Ethernet protocols supported by your GE 90/30 series controller (EGD, SRTP, and maybe Modbus/TCP) are also natively supported by the Allen-Bradley SLC-5/05 (A-B CSP, EtherNet/IP).
You can choose a chassis-mounted module or a network gateway, but there is definitely going to need to be some other hardware involved.
Hello All! I am writing today because I cannot figure this out for the life of me. Another site I am affiliated with keeps having their slc 5/03s...
194
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
110
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
121
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
129
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
147
