SLC 5/05 to Sixnet modem, RsLinx problem
Andy6
Apr 2011
In the garage.
140
Hey guys
I have a SLC 5/05 connected to a Sixnet VT-MODEM. When using RsLinx to dial into the modem, I can connect (seemingly) fine, but I'm having trouble seeing the 5/05. In RsLinx, it does recognize something is there, but it will cycle every few seconds between "Computer", a PLC-2/30, and a PLC-2, showing various states of connection (the red X's).
Now I think this has something to do with the comm settings, and although I've tried all the combinations I can think of, I still cant seem to get the proper connection.
I have a copy of the program, and the comm settings from the program act the same as above.
I was able to dial into this system at some point a year or so ago. I've been told that no changes have been done to the system since I was last there.
Any ideas?
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
97
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
105
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
116
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
106
Hello, I have a ControlLogix redundant controller being set up. The program reads a value from a remote site which hosts a SLC PLC. Rockwell...
89
