SLC 5/5 - compute instruction
venkum00
Dec 2005
Georgia
20
How can i get (N7:31 * 6 / 5) to work in compute instruction? This is very annoying. I know i am missing something?? Please help.
Thanks,
Ven
Thanks,
Ven
Use floats
transfer value of N7:31 to a float
make sure destination of compute is a float
i do not have pipe symbol on my laptop. Hmmm. I will look a little close.
Thanks for the info.
Ven
EDIT: you are correct. pipe symbol. I got it. Thanks a bunch :)-
Should look like this. No need to convert integer to float first. Result needs to be float.
Simplify the equation first.
N7:32 * 1.2
It doesn't make any sense to multiply by a constant and then divide by another conatant.
Alaric, you are correct. I simplified my original application and hence put in some numbers in the application. I do appreciate your input.
Thank you once again gmferg.
SLC 5/04 Does anyone know what the typical scan time is for the Compute instruction? The manual states "The execution time of a CPT instruction...
24
5,919
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
97
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
106
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
116
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
106
