slc 500 5/05 help
astronutt
Feb 2007
home
17
I am still tryn ta go online with this 5/05 with laptop and ethernet.I dont have a hub so i cut up a straight cable and spliced it into a crossover cable ,when i did this i got a green enet light and flashing flt light,but could not get online.Today i purchased a "real crossover cable" when i hooked it up i got flashing flt light but no green enet light.any help anyone should i have a light or not green enet light that is thx and include pdfs anything to get this going.
thx
Processor fault LED? Cycle the keyswitch to prgramm then to run. You need to know the enet IP address to use that method of comms...Does your PC have a serial port?
Chances are your SLC has an IP address but your PC does not. Make sure you go into your network settings on your PC and change the IP address to a fixed address like in the graphic I have included.
Before if you were on a network, the network was likely assigning you an address but with a crossover cable there is no one to perform this function. My example of an IP address may not be appropriate for your system. If I were you I would take the address from the SLC and either add one or subtract one from it. For example:
SLC 5/05 IP address: 192.168.0.11
Computer IP address: 192.168.0.10
Also make sure the mask setting is correct. For my example, 255.255.255.0 would be ok.
OG
Good Afternoon , I'm sorry. But I'm struggling to understand this combination of integers in this MOV , and really anywhere else this scheme...
1,606
Do I was able to configure a driver and get online with the plc and found an original program error from 1995 which they would have never noticed...
5,357
Hey guys, I'm trying to connect my laptop to an old SLC500 PLC. It has a DH-485 port on it and I have to configure a driver for it on taking. I...
1,380
I have a SLC 5/03 trainer PLC that I cannot connect to. I have tried several times with no luck. I was hoping to find someone local to help me...
1,537
Hello, I am a tech and I am trying to fix a 1994 Liberty Motor home with a Allen Bradly lighting and control system. The issue: The SLC 5/01 CPU...
2,209
