SLC 500 and PanelView 550
yani91
Sep 2006
Millersville
I am a college student that is trying to integrate a Panelview 550 and a SLC 500. I am having a hard time with downloading my program from Panelbuilder (v.2.40). I can not get RSLINX Lite (v. 1.70) to work either. The system I am trying to start on us by pushing a f1 on the PV 550 to turn on a motor and push f2 to turn off the same motor. Any information you can give me will be greatly appreciated.
you are using very old softwares please checkup with the hardware versions for compatibility!!!!!!!!!!!!!
The part number for the Panelview is 2711-K5A2. I am not sure how to configure the network because it wont let us open the configuration box. We have Rs Linx set up for 1747-PIC.
FYI: the programming cable for the SLC is different than the one used for the Panelview. They are both DB9 type connectors but one uses a straight serial and the other uses a null-modem. Radio Shack has both an adapter or seperate cables. JF
Yani, instead of playing Twenty Questions here, you should really contact your local Rockwell Automation distributor and have them walk you through the simple steps of getting this connected. While I appreciate that this is a neat public forum with helpful contributors, if I have to go through another PIC troubleshooting thread I'm going to scream.
Schaedler Yesco is the distributor who covers most of central Pennsylvania (if you're in *that* Millersville). Call and ask to talk to their PLC specialist and explain your situation.
If your university has an industrial technology program that doesn't have it's tools and documentation up to date, Rockwell and your distributor will likely appreciate the opportunity to get you set up with updates and introduced into the various educational toolkit programs that Rockwell Automation has.
As to your direct question: the first thing you need to do is build a workable DH-485 network using a 1747-AIC isolator module. The PanelView and the SLC-500 plug into the isolator, and then the 1747-PIC plugs into the PanelView terminal's other network plug.
If you happen to be using a computer with Windows XP, stop and go back to Step 1. You will not be able to make it work with the 1747-PIC driver and that long-obsolete version of RSLinx.
Hi guys..and girls if so.I'm a newbi,and also not very clued up when it comes to electronics.Can you possibily assist.My problems are:When I...
3,715
Hello I am currently having trouble with the tags and communication between SLC 500 and a Panelview 600 (RSLinx w/IP for communications) The...
4,731
Is there anywhere online to download code for graphics to use with the SLC 500. Things such as tanks, pumps, valves, ect.?
1,824
Hello, I read a thread about someone wanting to close a window and latch a bit with the same button and the reply was that you need to use...
8,758
I have a panelview 1000e that I'm trying to connect to a SLC 5/04.I'm using DH+ for the communications to the Panelview with rs232 going between...
9,872
