SLC 500 cable
I assume you're asking about a programming cable? I can't view the auction :( To connect to the SLC 500's serial port from a PC serial port, you need a null-modem cable.
Pin 1&6 to Pin 4
Pin 2 to Pin 3
Pin 3 to Pin 2
Pin 4 to Pin 1&6
Pin 5 to Pin 5
Pin 7 to Pin 8
Pin 8 to Pin 7
If you have an old fixed I/O SLC500, 5/01, or 5/02 CPU - the cable on ebay is what you need. If it is a 5/03, 5/04, or 5/05 with a serial port - the null modem cable will work. The ebay cable will also work with CH. 1 of a SLC 5/03.
If you are plugging into the DH485 (SLC 5/01, 5/02, 5/03), then you do need the adapter. It is an RS232 to RS485 electrical conversion with a special AB adaption.
A standard RS232<->RS485 converter will work if you are plugging directly into the processor. If you try a standard converter on a DH485 network, it will disable the network.
Good Morning , I just purchased a Windows 10 Hp Laptop. Of course no serial ports , but 3 USB ports . Need a USB to Serial cable to go to...
20
6,211
Does anyone know what smart cable can be used for SLC 500 PLC'S. Please mention a catlog number and a supplier. thanks kanwar
1,684
Hello all, I want to connect a SLC 500 (cat#1747L20G) to the serial port on my laptop. I was just going to create a pin1->1; pin2->2; etc...
19
12,745
Hi all, Just a quick question regarding puchasing a programming cable for an AB SLC 500. The PLC has a RJ-45 plug built directly into the unit...
3,520
I am new to Allen Bradley . I have a SLC 500 unit that I need to setup communication to and upload the program to a laptop for a backup and to use...
11,649
