SLC 500 communication problem
kelvinxu
Jun 2003
I make a 1784-CP3 cable by myself.But I tried many times to connect my laptop to the RS232 port of SLC500.But i never success.Is there somebody tell me how to connect it and make this cable?
Thanks a lot
Try it..
9 pin female 9 pin female
3-----------------------2
2-----------------------3
4-----------------------6 and 1
6 and 1-----------------4
7-----------------------8
5-----------------------5
8-----------------------7
Hope this help
Deer
I have made this cable
I have made this cable according to the description in the manual of SLC500.And i also set RSLINX driver to RS232 DF1 device.Then i press the auto-configure.I can not find the SLC.
I don't know why.
The serial port of an SLC can also be configured for DH485. If this is an SLC that has been in use the previous programmer may have set it up this way. In Linx try to configure a PIC driver, then connect using the same cable. Regards Alan Case
IT's Ok
Thanks everybody
I have found the problem.there are some problem with my laptop.Maybe it's damaged.Now i used a RS232-USB cable.It's ok.But shoud care you must set the setting of communication manually.Becasue it always stopped by BCC/CRC when auto-config.
After I tried wiring, I used computer program communication to read the PLC N value, but received a NAK signal. And the DL3500 CHA light keeps...
444
Transfered a program and project from one machine to another and no longer have communication. The 2 machines are twin machines in every way. We...
1,390
Good Morning , I cannot believe I forgot how to do this. It seems like I have been spoiled with everything being Ethernet. I have a SLC 500...
2,780
Hi everybody, We are repairing a stretch-forming machine that we bought heavily used and seriously dismembered. It has a HP computer running OS/2...
20
6,322
Hi Guys, I'm rather new on this forum, I've got a problem with my communication (RS232) with a Schneider (former Berger Lahr) stepper...
1,564
