SLC Ch0 Modbus
andy_1983
Mar 2018
uk
76
I'm trying to work out if I can use Channel 0 of my SLC CPUs (configured as Modbus Master) to talk to other manufacturers PLCs. I'm using new CPUs - so firmware is not an issue, and my version of RSL500 has option to configure Ch0 as Modbus....
Previously I've been doing this using a Prosoft Modbus card. I understand how to do this using the M0 & M1 files, and setting up telegrams etc.
is there a procedure I could use using Channel 0 of the CPU to read / write data tables from say a Mitsubishi Q series Modbus card - point to point?
I've been doing a bit of searching, and reading different help files - but not getting anything useful out of it!
Andy
Once the channel is set up for Modbus communications, you can use the MSG instruction to read data. Just pick MODBUS as the Target Device, then choose the type of MSG Read/Write, fill in the setup screen details properly and it should work.
You should not be required to manipulate the M0/M1 files directly.
Was wondering if this was possible, or if anyone has had experience with it.
1,938
Anyone know what an Allen-Bradley SLC5/04 Channel 0 DF1 error code of (HEX) 1015 represents?
1,453
Hi Guys pls advise best..and pain-free method to change from DH-485 to DF1 Thanks pillay
3,347
I am trying to link to a PV300 (not micro) that is directly connected to the Ch0 (DF1) port of a SLC 5/03 (OS302). My computer is connected to a...
5,653
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
97
