SLC distributed I/O - Ideas?
bentleya
Nov 2002
NE KY
69
Anyone have any good ideas for distributed I/O, utilizing an SLC 5/03 PLC? I have a project to look at within a building where I would like to mount the CPU within an office and use distribued I/O to the different MCC's, Control stations, etc. I haven't done this with Allen Bradley, so any ideas appreciated. (I/O will be 90% digital, with no special modules)
I'm probably looking at around 200 I/O points.
I happen to have an abundance of I/O, CPU, racks, etc. for the SLC - saving money you know.... :)
Anyone utilized Automation Direct's dist. I/O for the above?
Well, you could do traditional "Blue-Hose" RIO, DeviceNet or ControlNet. I hate RIO in a SLC, so I'd probably do DeviceNet or ControlNet.
I have used RIO in an SLC with the 1747-SN module and have had no problems. The rack addressing setup can be a little tricky if you have a complicated system, but once it's set up right, it works pretty well. CompactBlock I/O is probably the least expensive A-B option if you don't needs lots of I/O points.
Hundikoer said:
Definetly cheapest in-cabinet IO is Embedded IO AB has (plain PCB with connectors)
True, but I'm not sure I'd want to mount non-enclosed equipment in my panel, especially in an industrial environment.
That brings up a good point... I have noticed that motor drives and such can often be purchased with no enclosure--the circuitry is just hanging out there for everyone to poke at.
Does anyone have any opinions for/against using these models? (I think they are usually cheaper as Hundikoer pointed out.)
-John
Hi guys, I m experimenting with a distributed application consisting of 5 areas, each to use a SLC 5/04. The fifth is to be redundant using...
4,472
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
93
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
103
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
104
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
