SLC Overflow
SMOKE
May 2006
East and West of Kaos
475
I have read some threads on fault handeling, and reseting. Perhaps I dont understand yet.
I have some an alalog device that if the machine sits the reading will go past 32767. I dont care. As soon as the opperator moves this hydraulic device the reading is in the zone and all is well.
A previous programmer has put unlatch of s:5/0 at the start of the routine. I belive that the overflow is getting set and reset every scan and if gives me a majior fault.
Is there a way to ignore the overflow. What do I need to do.
Put it at the very end of ladder #2(see picture)
As a side note, if you have an STI in your program and it contains math that may overflow you should put an unlatch of S:5/0 at the end of the STI also. It is possible for an STI to trigger after the unlatch in the main program and before housekeeping. This is pretty unlikely but with the program scanning 100 times per second, sooner or later it will happen.
Keith
We are getting a fault...... Math Overflow Trap S:5/0 = 1 Apparently we are getting a value greater than 32767 or less than -32766. If...
7,835
I have an slc 504 that faults every couple of days. The overflow trap bit S:5/0 is set and I get major error code 0020. I read in the...
4,644
Can a math overflow in an STI file be automatically reset? Over the years, I've taken to adding one final rung in my MAIN (LAD:2) file, that is...
11,673
Greetings to all, this is one of those “yeah, it makes sense now that I think about it” type situations that most people never think about ...
19
16,868
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
95
