SLC Processor and Ethernet Comm ????
JoseM
Jul 2011
Texas
381
Got a quick question on ethernet communication. I have an SLC 5/05 who is talking via ethernet to a panel view and two other machines. The IP network where these machines are talking follows this scheme 191.16.xxx.xxx.
I'm also running a wireless network where a large quantity of the PLC's on the production floor can be access.
This particular SLC 5/05 is not part of the wireless network and I will like to added to it, Do I have to acquire a new Ethernet module to put on this PLC to be able to program it to join the wireless network which runs on a different IP scheme.
I do not believe you can buy ethernet modules for SLC's like you can for controllogix.
If you are using managed switches in your plant, you can set up routing tables to bridge the two LANs together. Talk to your IT department and see if this is possible.
The facility where I'm at has a Contrologix PLC with two DH+/RIO modules, Ethernet/IP module, and an Ethernet module (1756 -ENET).
all the PLC 5/04 are connected to this rack through DH+ and the PLC 5/05 is connected to the 1756-ENET module. This rack is also connected to a wireless router which I use to access all the PLC's remotely.
When I open RSLinx, it shows the Ethernet/IP module and it branches down with the other modules. I'm showing a picture of the set up for your information.
Hello Guys, I need to go online with a SLC/504 Ethernet processor but i do not have the program, nor do the customers. I've created an AB...
1,649
My computer is communicating with the 551 processor via ethernet but the two ethernet lights (near the ethernet jack) on the processor are not on...
2,058
I am trying to connect to a machine in my facility for troubleshooting, but I can't make it work. I am using a 1761-clb-pm02 from allen bradley...
18
3,176
Hello all, I have an SLC 5/05 series C (pic attached) but when I try to download a program it say it is a different series with a different FRN...
3,880
Hello, I have a SLC 5/04 processor that I can't get online with and hope someone can help me with any ideas. This processor has a DH+ and DH-485...
3,276
