slc servo
benjie007
Feb 2010
california
22
hey there folks, i currently have problem with slc servo system. Does anybody out there who is familiar with this kind of set-up?
The system uses slc5/04 to configure the slc servo card. my problem is,, the servo motor won't stop until the emergency activated. Help pls...
A lot more information will be required; all h/w part numbers and s/w listing. Was it a previously working system? Were there any changes to the system recently? Even something that appeared to be totally unrelated?
thank you so much jstolaruk. here are some of the information about the parts/hardwire.
SLC servo card 1746 HSRV
Termination panel 1746 HT
SLC 5/04 processor
Problem; servo runs wild and then after sometimes it stops with emergency lighted/activated.
here are the on-going troubleshooting we did.
-change the servo motor with new ones.(servo +resolver)
-change cable from servo motor to amplifier/driver.
-change SLC servo card.
- run the servo motor isolated from PLC by sending analog signal,
it runs accordingly.
; But,,still running wild on original set up. am going to paste a copy of the program on next posting.
Thank you so much guys.
I have a machine I'm trying to refurbish. Currently, it won't home without intervention. It's using a 1746-L532 processor with two 1746-HSRV SLC...
1,225
Hi, I'm new at PLC programming and my boss just bought a sureservo SVA-2100. We have a AB SLC 500 PLC and I want to know if I can use it to...
1,797
Dear Friends, We have a setting machine in which 20 Parker Servo Drives and motors (name plate images attached) used to place the tools at...
3,895
Ok, So I have a controller from a company called "Aerotech". I purchased an upgrade to allow the controller to communicate via Ethernet/IP...
16,445
Hello All! I am writing today because I cannot figure this out for the life of me. Another site I am affiliated with keeps having their slc 5/03s...
45
