SLC to CLX Enet MSG Via 1783NATR
ian.smith7
Aug 2002
UK
145
Hi All
I have been struggling with this problem for a good few hours now without success, so I definitely need some help.
I am trying to set up an ethernet message that writes from an SLC 5/05 in the Private Network to a CLX 5563 (v16.7 FW) in the Public Network of a 1783-NATR.
The NAT table is set up to give the SLC and a PV+ in the private network IP addresses in the Public Network.
The Gateway Address is set in the SLC to the Private Address of the NAT.
An SlC Map is set up in the CLX (21 Mapped to INT array).
I have messaging set up and working already in the same devices writing from the CLX to the SLC Via the 1783-NAT. I could probably do what is needed just reading and writing data from the CLX end but having failed to get this working I would like to figure out why.
I have tried too many different set ups in the NAT and the SLC MSG function to list them all but I wondered if anyone had a similar set up working and could offer some advice.
Cheers
Ian
Hi Firejo
Thanks for the reply.
Yes SLC mapping is set up in the CLX.
In the CLX 21 is mapped to a 'Control_Bits_Received' array of 20 INTs.
The SLC is sending 20 INTs to From N21:0 to N21:0 in the CLX.
I have just returned to work this morning and have sorted this out.
I needed a second line in the Multi-Hop tab directing the Data to Slot 0 in the CLX.
Although I am sure I tried this before without success. It is working now :confused:
Cheers
Ian
I can't tell you how many times I've forgotten about the multi-hop in an SLC/Micrologix MSG instruction. Good to hear it's running
Hi all I am replacing an SLC5/05 with a Compact Logix. Having converted the program I am now looking at the Ethernet messaging. I have Mapped the...
2,739
I'll start off by saying I'm unfamiliar with communications between PLC's, hence my question here. We have a machine with a ControlLogix & a SLC...
2,792
Anyone know if I can msg between a ControlLogix L71 (A) and an SLC5/05 (C) via backplane of second ControlLogix L71 (B)? ControlLogix (A) and SLC...
2,726
Hi there everyone! Long time lurker, first time poster. I am doing an SLC-5/03 to CompactLogix migration and am having an issue with a barcode...
1,052
Hi Everybody, I Am trying to write 10 integers from 1756-L72 (slot 0) with a 1756-ENBT/A (slot 1)to a SLC 1747-L552 over ethernet. Could somebody...
1,753
