SLC To Micrologix Messaging
recabite
Dec 2006
Beechworth
22
Greetings all
I have a messaging project i need to setup.
The decision has been made to retire one of our SLC 5/05s and replace it with a micrologix 1400. The old SLC was only used for messaging and has no I/O.
I understand that if i want to read/write from the micrologix to the SLC then i need to set up the target device as 500CPU, but what about read/write from the SLC to a micrologix what do i set up the target device as? SLCCPU,PLC5, or a CIF,?
Also is there any messaging problems (I/0 data words) that need to be addresed in sending messagies between the 2?
I have 5 SLC 503's that I want to network to a Micrologix 1100. All 503 CPU's have their channel 0 occupied so I need to use channel 1. Is this...
3,115
Greetings all I have a messaging project i need to setup. The decision has been made to retire one of our SLC 5/05s and replace it with a...
6,912
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
114
I'm attempting to read about 5 different PLC's and storing their data in a CompactLogix 5380 where I can manipulate the data I need. I am having...
19
4,057
Hello, I am currently trying to use a micrologix 1100 to read data from 7 SLC 5/05's and 3 Control Logix. I am only needing one word from each...
3,606
