SLC & Visual Basic Interfacing
The best way for a Visual Basic program to interact with the RSEmulate 500 program is to use RSLinx and the OPC Automation interface. This is very well documented.
You cannot use DMA. I do not think you have the budget to use the RSLinx SDK.
RSEmulate 500 can take over the serial port and emulate DF1 or DH485 protocol from that port. You could possibly connect from one serial port to another on the same machine, and use some third party communication driver.
For what purpose do you have to connect your Visual Basic program to the RSEmulate 500 program ?
If that is correct (and of course it is when Ken says so), then I was wrong before about it not being possible to connect to RS Emulate 500 because there would be no COM port to connect to.
I have only used Emulate 5, and I dont remember that there were any settings for taking over a real serial port. Maybe there is somewhere.
Hi everyone, I´m starting review a new aplication this aplicaction involved communicate a visual basic program (pc control) with a SLC 5/05, to...
2,009
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
107
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
118
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
121
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
108
