slc5/03 and panelview 600 need simple tips
moonert
Feb 2008
veldhoven
Hello all,
I'am starting to experiment with an pv 600 (2711-C6C9)and a SLC 5/03 processor.I have a few simple questions and need a few tips to start with the experiment.I managed to get a connection between the laptop and the screen using the DH 485 protocol.This works great!Uploading and downloading are no issue.I can get online with the SLC 5/03.No problem at all.Here are some questions I like an answer for:
1)If I make a button in Panelbuilder32 I need to create three tags for it (on/off,handshake).What is the most easy way to make them?Example please.
2)Can I communicate with the plc and the PV 600 and the laptop at the same time if i hook it up al together?What are the connections I need to make and on wich port of the devices?
3)Does somebody have a simple example with one button on the panelview and a piece of ladder in the plc (inc tags,node adres etc)?If I know this trick I can work it out myself.
Thanks for the help!!
Simon Jacobs
Netherlands
Does anyone know if it is detrimental to use a FULL straight through cable to connect these two. I know that the AB cable does not carry pin 9...
1,976
I have been searching past posts and manuals and I'm not understanding the mapping process. I have a SLC5/03 with a PanelView 600 and 1747-SN RIO...
4,860
I'm looking to make myself that cable. Anyone knows where I can find this cable pinout?
20
16,103
Hello,:) This is my scenario the ethenet of the slc is connected and the rs232 port is to be connected to the panelview. will the panelview...
4,584
Hi guys Unbeknownst to you but knownst to me I have used little clues from the forum and I managed to solve my issue. Now I'm no n00b on AB gear...
23,412
