SLC500 CPU - Module Properties in RSLinx or RSLogix
hpsustar
Apr 2023
Lynchburg, VA
Hello,
I am new to the industry and was wondering if someone could tell me if there is a way to check the module properties of the SLC500 series CPUs (specifically I am using SLC505) using ethernet comms and RSLinx or RSLogix500. When trying to use RSLinx and an ethernet devices driver, as I have done in the past with ControlLogix and CompactLogix modules, it does not give the option to see module properties. I am just wondering this in case I am in a plant somewhere and cannot see the physical module sticker on the physical unit and need to know what module I am dealing with and its properties. Can anyone point me in the write direction in figuring out this information? Thanks.
In RSLogix 500 you can double click on the IO configuration under the Controller portion of the tree. This will bring up a list of which cards are installed in each slot. This includes the part number and a brief description, but does not include firmware version. As far as I know, you will have to pull the module, with the power off, to get the rest of the data for the card.
You can right-click on the SLC-5/05's icon in the RSLinx Classic browse and select "Device Properties".
But the CIP Identity Object information that's listed there for Type/Code/Version isn't necessarily useful. The "Revision" listed there is not the Firmware Revision of the SLC or the EtherNet/IP daughtercard. And once the controller has a program with a name, the default Device Name that gives the Series / Revision isn't visible.
If the SLC-5/05 has its embedded Web server enabled, the series and revision and serial number information is available just by typing the IP address of the controller into a browser.
The SLC webserver got a little more sophisticated in Series C, but it's still pretty clunky. At least it's got an uptime value !
We bought a used SLC500 (1747-l40A) from a vendor. Comes with one year warranty. It's still on our test bench. I downloaded a program to it and...
21
4,231
Hello I want to communicate a HMI with a plc SLC500 (cpu 03). I have Magelis HMI (P/N: XBTH021010M130). I have the pinout cable for programming...
2,256
Hi all, i got a SLC500 CPU and somehow i cant communicate with it. Once i powered on, all LEDs are flashing. it was working fine before the power...
2,356
can you tell me how to clear a cpu fault,and what would have caused it
32,480
I have a slc500 plc 1747-L30A. Using a communication cable 1747-PIC cable box combination. Running a version of software from DOS on a Windows 3.1...
182
