Good Morning ,
We have a few 125 HP motors that have Soft Starts on them
and I would like to replace them with VFD's. What energy cost
savings would be expected by replacing the soft starts with VFD's. Our power company is giving rebates for drive applications ,and I would like to begin to investigate the
possibility of doing this. Would having a VFD alleviate the
peak demand for these motors or stay the same.
Thanks for your thoughts.
The question is much more complicated than laid out here.
IF the issue is reducing demand charge the easiest is to stagger start your motors such that you start only one in each time frame set by the utility ie one every 15 minute for example. As with other issues you should be talking to the utility for assistance.
Replacing soft start with VFD will not probably have much effect on motor starting power by itself. Nor will it have much efffect on power needed to start the load. Some - if not most - of this will depend on how you control the load.
Where VFDs can and do pay off is with loads that are subject to the affinity laws such as centrifugal pumps blowers etc. WIth these power is a cube function of speed so if you can run pump at half speed you are consuming only 1/8 the power than if run at full speed and doing discharge bypass.
EMPHASIZE this is controlling the LOAD not the MOTOR.
The motor draws 25% of full load amp to run itself the other 75% is what the load demands - this is what you must know to make this idea pay or not pay.
The main advantage of VFD is speed control. Speed ramps can go a long ways in reducing wear n tear on gearboxes drive belts etc especially so with loads that are frequently stopped started or reversed.
I think to summarize
1. IF utility is covering entire cost then go for it.
2. IF utility is covering 1/2 cost look seriously into it
3. IF you are hoping to recover costs from long term energy cost savings be very careful in analyzing your operating patterns and loads driven by motors.
4. Talk to the utility -- their engineers are supposed to know about this stuff and you are paying their wages anyway.
Dan Bentler
