Some pointers needed. VIPA, TIA, x86, x64, EKB 6ES7 972-0CB20-0XA0
PX200
May 2017
Vienna
Hi guys,
Some pointers needed:
Having PC with WIN7 pro X64 and Amsamotion clone of 6ES7 972-0CB20-0XA0 cable and need to backup VIPA cpu 315sb 2ag12 PLC
Manual says that it needs to be configured as SIEMENS ("The CPU is configured as CPU 318-2 (6ES7 318-2AJ00-0AB0/V3.0) from
Siemens.")
Ok. Now..
1. Which software to download for the job ? (Win7 pro X64 remember ? )
(I stuck with x64 usb drivers for interface allready - no drivers)
2. Any pointers welcome.
Kind thanks.
:site:
VIPA with Siemens TIA - yikes !
I dont think that the 6ES7972-0CB20-0XA0 will work. AFAIK only Siemens software knows how to connect to the PC Adapter with USB interface.
Then on the other hand, I dont know of anyone that has made a clone of the PC Adapter with USB interface. There are plente of clones of PC Adapter with serial interface though. Are you sure it is not a PC Adapter clone with serial interface ?
Anyway, forget the PC Adapter, the VIPA CPU 315-2AG12 has an integrated ethernet interface. You use that to go online, I believe you must setup a project with a 318-2DP plus CP343-1.
But...
The manual says you must have good knowledge of Siemens S7 already.
And... there is a risk that TIA wont play well with the VIPA CPU.
Hi Jesper,
Thnx for your reply.
You are most certainly right.. it is somekind of usb to serial - since first autoinstalled drivers are some FTDI 232 .. or prolific or something..
I described it (possible wrongly) purely due to fact that I insert one side to usb and other (DB9) to plc :)
And since I am not fully familliar with protocols here - I thought that that is some multiprotocol dongle interface..
Nevertheless I have some SIEMENS S7 plc on disposition and I'll try it there prior to VIPA.
I will download and install tia potal 14.1 then try to establish communication through dongle interface..
Kind regards
If you want to use the PC Adapter clone, you probably have to select the interface serial PC Adapter and specify the virtual COM port. But that is assuming that it is supported by TIA, and that would surprise me.
Go for the ethernet connection instead of the PC adapter.
And if I had the choice I would use STEP7 V5 (aka "Classic") instead of TIA.
Hm.. This Siemens are hard to grasp.
So.. I buy let's say this interface :
And I can't use it with most recent SIEMENS PG software ?
And it's difficult to separate TIA from rest of the stuff ..
Is this TIA I'm downloading or Step 7 ?
Bcoz all the links somehow seems to take you to different product than named in hyperlinks ??!
https://support.industry.siemens.co...plcsim-v14-sp1-trial-download-?dti=0&lc=en-DE
I don't remember exactely but I wanted TIA 14 and ended up on STEP 7 14.x
:mad::mad:
The picture you posted is the Siemens PC Adapter USB A2, not a clone.
I believe you can use it with TIA.
If you have STEP7 V14, then you also have TIA V14.
It is called TIA Portal because within TIA you can have several programs. Fopr example STEP7 and WinCC.
Still, I cannot say if there might be a hitch when running TIA with a VIPA.
I have exactely same device..
but I am loosing it now with.. :
https://support.industry.siemens.co...plcsim-v14-sp1-trial-download-?dti=0&lc=en-US
Is THIS what i need to DL and install ????
STEP 7 Professional V14 SP1:
DVD 1: (STEP 7 Prof. V14 SP1)
Registrierung notwendig SIMATIC_STEP_7_Professional_V14_SP1.001 (2.0 GB)
Registrierung notwendig SIMATIC_STEP_7_Professional_V14_SP1.002 (2.0 GB)
Registrierung notwendig SIMATIC_STEP_7_Professional_V14_SP1.003 (1.1 GB)
Registrierung notwendig SIMATIC_STEP_7_Professional_V14_SP1.exe (2,8 MB)
Bcoz I did. Can't pass even through install path step !!!
Run as admin but still cant't find any path and just exits from installation.
Path file not found
Unbelievable.
Code:
############################## --------- START20200318102121 --------- ##############################
10:21:21|          |CreateExtractionLogFile             |Master Log File : C:\ProgramData\Siemens\Automation\Logfiles\SiWA.log
10:21:21|          |SiWA Masterframe Version            |03.05.01.00_01.01.00.10
10:21:21|          |GUI Mode                            |Full GUI
10:21:21|          |CSiWAInitalizer::Init               |Initializing the package settings
10:21:21|          |PackageName                         |SIMATIC STEP 7 Basic V14.0 SP1
10:21:21|          |Date                                |Wednesday, March 18, 2020
-------------------------------------- System Information --------------------------------------
10:21:21|          |RAM Size                            |4.00 GB
10:21:21|          |Processor 1                         |Intel(R) Core(TM) i5-4300M CPU @ 2.60GHz
10:21:21|          |Processor 2                         |Intel(R) Core(TM) i5-4300M CPU @ 2.60GHz
10:21:21|          |Processor 3                         |Intel(R) Core(TM) i5-4300M CPU @ 2.60GHz
10:21:21|          |Processor 4                         |Intel(R) Core(TM) i5-4300M CPU @ 2.60GHz
10:21:21|          |Computer name                       |T440
10:21:21|          |Space Info on Drive: C:\ (NTFS)     |Total Space: 465.76 GB	Used space: 325.71 GB	Free space: 140.05 GB
10:21:21|          |OSVersion                           |OS Version : 6.1.7601.2
10:21:21|          |OSVersion                           |Major Version : 6
10:21:21|          |OSVersion                           |Minor Version : 1
10:21:21|          |OSVersion                           |Product Type : 1
10:21:21|          |System Language                     |Croatian (1050)
10:21:21|          |UI Language                         |English (1033)
10:21:21|          |InitAutolaunch                      |AutoLaunch is enabled
10:21:21|          |SetWaitForAutoLaunchParam           |Invalid value for WaitForAutolaunchFinish. WaitForAutolaunchFinish is enabled by default
10:21:21|          |InitCommandLineForNoOSCheck         |Setting NoOSCheck from INI file.
10:21:21|          |InitCommandLineForNoOSCheck         |NoOSCheck has been set.OS check will not be done.
10:21:21|          |                                    |Windows7ExtractPath :
10:21:21|          |                                    |Windows61ExtractPath :
10:21:21|          |CSiWAInitalizer::ValidateAndCheckExtractPath( |Extract Path from Web Package : %TEMP%\SIMATIC STEP 7 Basic V14.0 SP1
10:21:21|          |CheckFreeSpace                      |Drive C:.  Available space : 140.05 GB
10:21:21|          |CheckFreeSpace                      |Required space : 5.51 GB
10:21:21|          |CheckFreeSpace                      |Comparing Available space : 150372401152 Bytes and Required space  5917249161 Bytes
10:21:21|          |Display Name                        |STEP 7 Basic V14.0 SP1
10:21:21|          |GetCheckAdmin                       |Admin rights needed for extraction
10:21:21|          |ValidateOSBeforeExtraction          |NoOSCheck is set
10:21:21|          |Setuptype                           |PLUS
10:21:25|          |IsParameterFileNotCorrupt           |Generating hash code for  : C:\{522E0D77-A2E6-4B98-A21B-61A2511FC48F}\Properties_SiWA.ini
10:21:25|          |SetSelectedUserLang                 |Setting the radio button for LanguageID : 1033
10:21:26|          |IsParameterFileNotCorrupt           |Generating hash code for  : C:\{522E0D77-A2E6-4B98-A21B-61A2511FC48F}\Properties_SiWA.ini
10:21:26|          |NonameFunction                     |Autolaunch is enabled
10:21:27|          |DirChangePage::OnWizardNext         |Overwrite check box is unchecked
10:21:27|          |ValidatePathAndSpaceAvailable       |Validating the Extract path : C:\Users\Nhjhj\AppData\Local\Temp\SIMATIC STEP 7 Basic V14.0 SP1
10:21:27|          |ValidatePathAndSpaceAvailable       |Checking the space availability in : C:\Users\Nhjhj\AppData\Local\Temp\SIMATIC STEP 7 Basic V14.0 SP1
10:21:27|          |CheckFreeSpace                      |Drive C:.  Available space : 140.05 GB
10:21:28|          |CheckFreeSpace                      |Required space : 5.51 GB
10:21:28|          |CheckFreeSpace                      |Comparing Available space : 150372302848 Bytes and Required space  5917249161 Bytes
10:21:28|          |ValidatePathAndSpaceAvailable       |Extract Path : C:\Users\Nhjhj\AppData\Local\Temp\SIMATIC STEP 7 Basic V14.0 SP1\
10:21:28|          |ExtractPackage                      |Extracting the Setup to : C:\Users\Nhjhj\AppData\Local\Temp\SIMATIC STEP 7 Basic V14.0 SP1\
10:21:28|          |ExtractPackage                      |Checking for parts
10:21:28|ERROR     |ExtractPackage                      |Multi part File not found : C:\Users\Nhjhj\Desktop\PLCs\SIEMENS\TEMP for step 7\SIMATIC_STEP_7_Basic_V14_SP1.001
10:21:41|          |Temp directory :                    |C:\{522E0D77-A2E6-4B98-A21B-61A2511FC48F}
10:21:41|          |Deleting folder :                   |C:\{522E0D77-A2E6-4B98-A21B-61A2511FC48F}
######## --------- START SUMMARY 20200318102121           ##############################
10:21:41|RETURN    |STATUS                                |Fail
10:21:41|RETURN    |ERRORS                                |1
10:21:41|RETURN    |WARNINGS                              |0
1 Errors found and 0 Warnings found
############################## --------- End --------- ##############################
I think the Trial STEP7 Professional is the right package for you.
Not sure what goes wrong for you.
I notice that it says you have 4 GB RAM, is that correct ?
I would not run TIA on anything less than 16 GB.
Good spot. I noticed it also. I thought that I have 8GB
That's some old T440p which will be used as PG.
480 SSD and 32GB will bi fitted.
But still think that install should went through..
I'll try to solve it out..
Thnx for your replys.
It's so easy to be stupid.. :)
Mode LastWriteTime Length Name
-a--- 18.3.2020. 12:49 0 dirlist
-a--- 18.3.2020. 12:49 640 dirlist.txt
-a--- 17.3.2020. 23:08 1216355844 SIMATIC_STEP_7_Basic_V14_SP1.003
-a--- 18.3.2020. 6:15 2911112 SIMATIC_STEP_7_Basic_V14_SP1.exe
-a--- 17.3.2020. 15:19 2147483647 SIMATIC_STEP_7_Professional_V14_SP1.001
-a--- 17.3.2020. 21:13 2147483647 SIMATIC_STEP_7_Professional_V14_SP1.002
Kind regards
Now (off course) needed CPU/PLC is NOT on the supported list..
(JUST to keep you guys updated)
Please do always use the CPU 318-2 (6ES7 318-2AJ00-0AB0/V3.0) from
Siemens of the hardware catalog to project this CPU from VIPA.
For the project engineering, a thorough knowledge of the Siemens
SIMATIC Manager and the hardware configurator from Siemens is
required!
So I need step 7 v5.6
https://support.industry.siemens.co...which-programs-work/215361?page=0&pageSize=10
Which I can't download prior to clearence due to some export restrictions???!
Code:
You cannot download this file, since your registration inquiry is still being processed.
Please note: due to the manual review, the registration may take several days.
You will get a confirmation e-mail as soon as your download registration is finalized.
You can download the software packages with export restrictions only when you have received the positive confirmation.
:confused:
Any alternative locations for downloading
SIMATIC_STEP7_V56_SP1.exe (2,3 GB) ???
Kind regards
They'll usually approve you eventually, but it can take a couple days under normal circumstances. I wouldn't be surprised to hear it take longer these days.
Essentially, due to legal restrictions, companies need to prove they are not distributing certain kinds of software to embargoed coutries (like North Korea), terrorist organizations, etc. If you're receiving the software because you bought it and have a business relationship with them, that is typically pretty easy to verify. If you're just some random guy from the internet with a free account, it takes longer before they decide that you're unlikely to get them in trouble.
Approved.
But question remains - will it will work on Win7 Pro x64 ?
v 5.3 wants XP with SP1 I think.
Hopfully this one will work.
Installed and it runs.
I'll maybe record VIPA PLC backup procedure and upload to gdrive if someone is interested.
Approved.
If you had read either the readme or the release documents link at the v5.6 trial software download site, you would have seen that it supports:
MS Windows 7 (64bit) Professional, Enterprise with SP1
(to be fair, the documents are slightly different. The other also lists Ultimate as an option)
Hello, I've just came out of a call where a program that was modified two weeks ago threw the processor into fault. The program has been done...
3,471
I'm trying to get a 5069-L306er to talk to a Automation Direct ProSence Controller by using RA's AOI for modbus client but its stuck not getting a...
1,884
The last time I did anything with Wonderware was just after the dot com bust. Boy, I feel old. Anyway, it looks like I will get the chance to...
1,522
Is there any form of Reference Type or Pointer Type like Codesys has? I am aware that you can nut a tag in the index of an array reference. but...
1,897
Hello Everyone, I am making an FB that is going to retrieve information from a Pilz Multi. The information given from the Pilz Multi is made up...
1,436
