somebody can help to solve?
jayozengo
May 2006
penang
how to store a result that content 8digit to lower four BCD number of the result in 200(address) & upper four in 201???
result=12345678 where 1234 is upper & 5678 is lower
you are talking about a float data right,jayozengo? Mind me asking what make of PLC are you working on? Different PLCs have their ways of processing.
If you are using a double (32bit variable) maybe you just need to use a funtions like "DINT_TO_BCD" but this will depend on which PLC you are using
i need de panelbuilder software from rockwell, im trying learn about this HMI, i was looking on the web but i nver founded, plis if anyone got the...
22
40,973
Hi Received a PM from this guy. I've got no idea...
4,470
i used mvi56_adm moudle at 2002, it work perfectly, at 2003, i used mvi47_adm moudle , it work perfectly too, this time , mvi71_adm is required...
1,638
Hello: I'm very curious about PLC but I don't know much about that. I have a question to solve: For changing the set-point of an automatic votage...
4,139
