Sort or Compare 20 Values
javaninger
Mar 2010
mo
I currently have an array with 20 counters. I would like to find the top (highest .ACC value) five of the total 20 and use that information.
I need to compare all 20 counters.
Take largest 5.
Counter0.ACC = 2
Counter1.ACC = 4
Counter2.ACC = 3
Counter3.ACC = 7
Counter4.ACC = 10
Counter5.ACC = 2
so on....
(I could do this as string or some other method)
TopFive0 = Counter4
TopFive1 = Counter3
TopFive2 = Counter1
so on....
Any thoughts? I am thinking the data could be stored in a UDT.
Thanks,
John
Take largest 5.
Counter0.ACC = 2
Counter1.ACC = 4
Counter2.ACC = 3
Counter3.ACC = 7
Counter4.ACC = 10
Counter5.ACC = 2
so on....
TopFive0 = Counter4
TopFive1 = Counter3
TopFive2 = Counter1
so on....
Thanks,
John
Are you looking to store just the "values" of the largest 5 or the "indentity" of the largest 5.
So if I wanted to sort the counters, I would have to copy their value to another array like SortedCounters[20]? Would this array just be an array of INT's then?
It would be a DINT array.
Use an FAL instruction to copy the counter[falcontrol.pos].acc to the array[falcontrol.pos] and then sort the array.
If it is simply just values you are concerned about, first make your counter an array.
Counter[0].ACC, Counter[1].ACC, etc.
Then make another 5 DINT array for your values
TopFive[0], TopFive[1], etc
What happens if several counters tie for fifth place?
I have an unusual task with a PanelView Plus 7 (running v11 firmware) and a CompactLogix. The customer wants to place a version number string in...
628
Hello all, I was looking into different sorting techniques and actually found a bubble/insertion sort sample code file on Rockwell's site. Only...
20
5,339
Hello all, I am attempting to sort a selection list via 'part-selection' buttons. Ex. a certain type of model is selected, I only want to have...
1,383
I am storing values into an array. I am wanting to find an average of the highs and an average of the lows. Something like this... After 50...
36
8,949
Hello, I been trying to sort some values in the the Do-more PLC but still have some issues. I have 20 elements from the data view with random...
3,687
